This is a copy from the old board showing our previous oil sample from back in Dec of 2001.
[ November 02, 2002, 09:43 AM: Message edited by: BOBISTHEOILGUY ]
I believe Terry has some updated info to post on the continuation from this truck. Look forward to seeing this as I have not seen it myself.code:
Cummings 5.9L turbo.. oil analysis
Date: 18 Dec 2001
Time: 15:45:37
Comments
I just got a new oil analysis report on a 6 cly
5.9l turbo cummings desiel..
truck has total of 40,579miles on engine at last
oil sample taken.
truck has had a top of the line amsoil 15w40
prior to schaeffers put in. amsoil had 14,724
miles at time schaeffers supreme 7000 15w40 blend
was put in. amsoils oil looked good, wear numbers
showed a little higher due to some of the
leaching caused from a new engine, but overall
had an acceptable tbn level. the exact specifics
on this sample is priprortory and was asked not
to share any more specifics with this piticular
analysis sample.
now here is schaeffers blend..
miles on this oil is 13455, filter was changed at
the beginning when schaeffers was first installed
27224 miles on truck. there is also more hours on
this oil as well not included in this report.
glycol- neg,
%water-
%fuel-
visc-100deg C 13.5(little higher than other),
%solids-na,
soot-NA,
%oxo-13.3,
%nox-7.1,
TBN- 10.5 (tbn on new oil is 10.5),
Tan-NA,
Fe iron-74,
Cr chromium-3,
Lead-5,
copper-67,
tin-1,
aluminum-11,
nickel-0,
silver-0,
manganese- 1,
silicon-10,
boron-27,
sodium-3,
magnesium-15,
calcium-2672,
barium-0,
phosphorus-961,
zinc-1280,
molybdenuim-105,
titanium- 0,
vanadium-0,
cadmium-0
where the higher levels of wear appear is
actually lower than amsoils numbers which shows
that what ever was in the engine is comming down.
point i bring on this analysis is that compared
to amsoils top of the line full synth, the blend
shows to be holding every bit as good at this
point in the test for near half the cost of the
full synth.
we are going to change filters, top off and
continue on with this oil.
tests have been provided by Dyson Analysis. (
http://www.bobistheoilguy.com/terry.html )
