Car is a 2001 Honda Civic 2DR EX Coupe.
First let me prefix this by saying I have already searched and read every thread in regards to the Battery Light staying on.
I took my car to my mechanic and he first tried to turn if off but could not.
I then took it to Hersons Honda who also cant seem to figure out this **** Battery Light problem.
First let me explain what we have tried:
1.) Checked the volts on the alternator and there are fine. They measure 14-14.2 Volts. This was measured by both the Honda tech and my mechanic.
2.) Battery was replaced twice. I replaced it 3 weeks ago first. Then on Sunday I went back to Advance auto parts to change it again just in case something was wrong with it.
3.) We checked every single fuse under the dase and under the hood and there ok.
4.) We checked for bad grounds and can’t seem to find any.
5.) Alternator Belt is not loose. It is on tight. Alternator belt/power steering belt/timing belt where changed in February and never had a problem.
6.) My mechanic took out the ECU Fuse under the hood, but the light came back on. Honda tried to reset it and they said the same thing.
7.) I even replace the alternator and the light still stays on.
Honda thinks it MIGHT be a problem with a short on a cable from the ECU to the Dash board, or the ECU to the alternator or battery.
I think there just fishing for answers because they have no clue what’s wrong with it. They said they would have to pull the dash apart and checking the above recommendation would cost $350.
I told them no way.
I also ran the OBD Reader but no codes were returned. I just did this for good measure as there was no check engine light anyways but i wanted to be sure.
What could it be?
Thanks again in advance.
Oren
Here is the diagnoses from the previous alternator (now replaced with a new one).
It has the battery test and alternator included.
I told them no way.
What could it be?
Oren
