Recently my '99 Toyota Sienna (1MZ-FE engine) has developed a noticeable knock when operating at certain RPMs. You can make the noise by reving up to about 2600 RPM and then it will make a louder knock when backing off just a bit. It goes away at higher RPMs. The location of the noise is hard to pin down but sounds as though it is coming from the top of the engine and only appears when warmed up.
I have used Mobil 1 in this engine since new and have changed the oil every 4500 miles or so, the engine has 150,000 miles on it now.
I did some searching here as well on Usenet but only found people posting similar questions (no real answers). Does anyone have any thoughts on what this might be before I take it to the dealer for a diagnosis?
I have a hard time believing it is wear of some sort with my OCIs and use of synthetic, but who knows. What about a bad knock sensor? I generally use 92 or better octane gas (the manual "recommends" this octane) but different gas seems to make no difference. It sure isn't what I remember "pinging" to sound like, it is much more of a deep-seated knocking that doesn't sound very nice
