anyone see an issue with this??
By meaning of my handle, you get the idea that we explore the great outdoors a lot. Well, after so many thousands of miles, I finally come up with the idea, instead of always having to hose out the front/back of the radiator for the thousands of bugs, rocks, etc that get caught in the fins, to install a screen mesh type material from the top of the radiator all the way down.
What I did was install the screen mesh in front of the grill on the upper part of the radiator, so that it's not sucked up against the radiator itself; but below the front bumper, it is pretty close against the bottom of the radiator and the electric fan, but pulled fairly tight so that it doesn't bunch up in a bundle and block off air.
Took it for a 30 mile drive in 91F heat, didn't see any problems thus far.
Anyone see a problem with this?
