first i will say that i searched bitog forums, as well as the first 5 pages of google.
now, i plugged in my obd2 code reader after my check engine light came on. i am getting the code p1496.
my code reader explains to me that this code means
"P1496 5 volt sensor feed is sensed to be below an acceptable limit (under 4v for 4 sec"
thats all fine and dandy but i dont know where the sensor feed is, or the 5 v voltage regulator, if it does have one which i am starting to assume it does.
has anyone seen a similar problem in anoher chrysler vehicle and does anyone have a suggestion for fixing the problem?
im starting to think the computer may be faulty, but at this point id rather not throw parts at it.
the only symptoms i have is an occasional random stalling. once every 50 miles or so the engine will buck for a second as if someone momentairly turned the key off. but it comes right back on and everything returns to normal in a second or so.
thanks.
thanks.
