One of the reasons I like to rebuild my calipers myself is to make sure they go back together with a good coat of Sil-Glyde on everything and not some hygroscopic crap like brake fluid or a glycol soap. Only bean counters would use something like that. At least here in the salt belt, one of the main brake problems is corrosion of the outer part of the piston. It doesn't see the brake fluid from one pad change to the next. What is on the the outer part of the piston, is mainly what it was lubed with on assembly. It has nothing but the boot to keep the salt, moisture, and grit away from it. The chrome plating is abraded as the piston slowly works it way out of the seal. One more time guys. How does changing the fluid protect the part of the piston beyond the seal?quote:
Originally posted by John Hilmer:
Woha, I didn't mean to start a war over grease and brake fluid, sorry.
The Toyota manual shows two versions of rebuild kits. One supplies "Lithium soap base glycol grease, for all sliding surfaces." and the second supplies none. In the second case they state to soak the piston in break fluid prior to installation and to use silicone based or high temperature multi-purpose grease on the pins.
Regarding the drain and refill issue they state to do this if any contamination is seen. This brings up a new question for me.
What causes the fluid to become black. The wifes '96 Camry is black so I'll change that out, but what is the source that causes it to get like that? It seems a waste to just drain and replace the fluid if there are seals/lines etc that are decomposing and coloring the fluid. If it is soil ingress then I assume the caliper seals and the like need replaced.
You folks have been a big help to me so far, a bit more help here would be much appreciated. John
Nice somebody else has looked at a brake caliper and realized flushing the fluid may not push the crud up out of the bleeder. I also question how much of the old stuff in the narrow clearance between the piston and bore is flushed out.
Brake fluid that has extracted a little carbon black filler from the rubber parts will continue to work fine. It is like changing the oil in a diesel as soon as it turns black from soot.
Notice how what was likely a purely mechanical problem external to the caliper fluid has turned into an insistence on the useless changing of fluid.
