Hi all, noob to this forum (first post).
I bought a 1946 Willys jeep awhile ago and put it in storage, it needs alot of work.
When I bought it, the engine (134 cu. in.) flathead 4 cylinder had no oil filter, the guy I bought the jeep from apparently removed the old bypass filter and just plugged the feed & drain.
I'm wondering what my options are, is there a better filtration system for my jeep or should I just put another bypass filter unit on and not worry about it.
Please keep in mind that this engine never came with nor was it designed to use a full flow filter assy, it came with only a bypass filter from the factory.
Any suggestions would be much appreciated.
Bill
Bill
