My wife's '03 3.2TL PS fluid looks pretty bad at 40k miles. I'd like to exchange it with new honda fluid. Can anybody let me know if my plan sounds reasonable?
The PS reservoir has two hoses going into it, one stacked about 1" directly above the other. It makes sense to me that the Upper is the return line, and the lower is the line going to the PS pump itself.
My thought is that I could disconnect the upper return line and plug the hole in the reservior. Next I would allow the return line to flow into a bucket or something. Start the car and keep filling the reservoir with clean fluid (not allowing it to run dry).
Allow the dirty fluid to be pumped out the return line until it runs clean into the bucket..then turn off the car, reconnect the return line to the reservoir and top off.
Anybody see a problem with this procedure?
Can anybody confirm that my assumption about the my identification of which one would be the return line?
Thanks in advance for any help with this
