This is on sale at Canadian Tire. Although the idea of the fluid heating sounds good, I'm questioning the benefits of its usage on really cold windshield. Will it not crack if the temperature difference is about 80C? OK, it might not heat up to +60C if it is -20C outside. And the fluid will eventually cool down quite a bit while traveling in the air. But the temperature difference still sounds quite dramatic for the glass... I wonder how hot (warm) would the fluid be when it hits the glass.
What do you think?
What do you think?
