not 100% positive in this scenario, but generally power jets are a boost for a specific rpm or throttle position. On motocross bikes they were used for 0 to like 50% as a boost in low end fuel to aid in torque. However on the same basic carbs but swapped over to methanol for microsprints the power jet was used as a 75% to 100% throttle situations as you couldnt shove enough fuel through the main jet. they added approx .080 to a main that was at .112 or so. lotta fuel for a 250cc 2 stroke..
44H
44H
