quote:
Originally posted by Winston:
That is an awfull lot of oil you are burning. You said that after they changed the rings the oil consumption was not any better. Are you sure they actually did the work?
No, actually, I'm not sure. I wondered the same thing myself. The dealership sure did keep the car a long time to do nothing, if that was the case.
OK, now I reread everything. This is your second engine? If you count the re-ring job, this is your third engine?!?! All had the same symptom of burning a quart every 500miles?!?!
Yep, only now it's like a quart every 300 miles.
With the ARX, are you using synthetic oil?
I'm not running synthetic anymore. Using Chevron Delo 15W-40 oil now. Same rate of consumption.
Have you done an oil analysis? Do you have coolant in the oil? How about fuel dilution? [/QB]
