Wondering if anyone has experience replacing the fan clutch on the 2002+ 4.2 I6 Chevy Trailblazer?(GMC Envoy, Olds Bravada, Isuzu Ascender are others that are the same.) I have a new design clutch in the box that's supposed to fix a poor a/c performance issue, and I need to get'er done, but have read several ways to go about it including the GM SI that has you just about take the whole front-end apart! Also any advice busting the clutch nut loose from the water pump shaft? THANKS!
