I'm currently driving a '94 Chevy S10 Blazer with 142k miles, on permanent "loan" to me from my father in law. I get to drive it whenever I want, with the understanding that I buy the gas & do the oil changes.
The Blazer had been running perfectly until last week. It has developed a nasty habit of sputtering, stalling when I come to a stop, & a bad burning carbon smell. These symptoms do not happen every time I drive it, only about 1 out of 4 trips. The service engine soon light also comes on after these symptoms have been present for a few minutes.
I'm thinking of the following possibilities:
1. Failing fuel pump (or a short somewhere in the wiring), causing it to run lean, thus the burned carbon smell from the catalytic converter.
2. Dirty fuel filter, not allowing enough fuel to reach the engine, which in turn causes the sputtering, stalling, running lean, etc.
3. Bad Spark plug, sending unburned fuel to the cat., which results in the cat. overheating & causing the burned carbon smell.
4. Bad spark plug wire
5. Clogged catalytic converter (not sure if this is even possible???)
Am I on the right track, or do the BITOGers have some more suggestions? Thanks in advance.
