Dealer says my VW/Audi 1.8T needs a throttle body service. Do I just spray carb cleaner into the intake?
Thanks.
Thanks.
It worked great for me also.quote:
Originally posted by Chevynut67:
You can give Valvoline Synpower Carb & TB Cleaner a shot. I used it on my '98 Blazer last year with great results.
Don't Fords have FI? How'd the Techron get into the TB?quote:
I was under the impression that Techron, while quite good, only cleaned the fuel injectors and intake valves, but not the throttle body. I always wondered how it could clean those two areas and not clean the TB.
So you don't remove the TB before you clean it?quote:
Also, the carb cleaner will kill O2 sensors.
