sorry sarge i know a bit about this as well, with a masters degree in environmental engineering. brake fluid and antifreeze are primarily glycol based blends, which degrade (they are not "separated") in a biological treatment process, which most wastewater plants in the united states have. you can flush a little at a time and it will not cause a problem:quote:
Originally posted by sgt_barks:
Ok guys this I know something about.
Your water treatment facility IS NOT equiped to seperate these things out of the water. So how many ppm of brake fluid would you like with your icewater? Antifreeze too. Never put anything other than organic substances or mild degerants down the sanitary sewer. Did you know bacon grease can mess it up?
You can take those fluids to any oil change place and most auto parts store and dispose of them. Keep your fuels, oils, and antifreeze seperate. Don't mix different types of fuel. When you mix them it ruins their ability to be recycled. You can mix all oils together to include brake fluid, ATF, motor oil, gear oil, etc. It is not ideal to mix dexcool and regular green stuff for recycling purposes. But it can be done.
I am an Environmental Compliance Officer. This stuff is all I deal with. The military and Fort Hood in particular have many systems to avoid contaminating the ground water.
By the way. These fluids will severly mess up the ground water if let into the storm sewer. if you must change antifreeze in your drive way, take care not to let it into the storm sewer. When cleaning up, use absorbant or wash it into the yard. Your yard has a filtering effect that will minimize the impact on the greound water. If dilluted enough with a water hose it won't kill your grass either. Try absorbant first though.
Ok I'm done, wake up
automotive fluids disposal
don't mix brake fluid (at least dot-3/dot-4) with oil unless you want a mess on your hands.
