RARE HID installation
by Kira
Today at 08:51 AM
ATP AT-205 good engine cleaner ?
by kr_bitog
Today at 06:16 AM
List of VOA's from Russian Oil Club
by spiderbypass
Today at 01:43 AM
Quicksilver Prem Plus
by jmw116
Today at 01:39 AM
Creating white letter tires
by turtlevette
Today at 12:22 AM
Hypothetical Question On Incorrect Filters
by Triton_330
Today at 12:18 AM
Pennzoil $2.99/qt at tractor supply!
by Chris142
Yesterday at 10:25 PM
Brother passed away this morning
by oilboy123
Yesterday at 10:21 PM
Changed oil tonight - what a fine evening
by pacem
Yesterday at 10:10 PM
Interesting observation on Ultra
by RusskiBoSS
Yesterday at 08:48 PM
2009 Honda Civic Cooling fan running continuously
by Doog
Yesterday at 08:31 PM
adhesive for pea gravel?
by xfactor9
Yesterday at 08:19 PM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
75 registered (4wheeldog, Bandito440, alienyzf, Bgallagher, AutoCoil, 5 invisible), 1699 Guests and 351 Spiders online.
57973 Members
66 Forums
249376 Topics
#564948 - 06/05/05 09:18 AM PCV valve rattling?
Drew99GT Offline
Loc: Colorado Springs
Hmmmm, never heard this one. Was checking my A/C charge the other night with the engine idling, and whenever the compressor kicked off, there was a rattle from the PCV. Confirmed with the mechanics stethescope (ala screwdriver). It is a Fram. Must be busted somehow, like the plunger can't seal flat in there so it's just rattling around. My idle has been a bit rough as of late. Guess I'll try a dealer valve and see if it works.
#564949 - 06/05/05 11:45 PM Re: PCV valve rattling?
kenw Offline
Loc: Houston
when you shake a PCV is SHOULD rattle. The spring is quite weak so that only a slight pressure in the crankcase or slight vacuum from the manifold will open it.
#564950 - 06/07/05 09:30 AM Re: PCV valve rattling?
Drew99GT Offline
It's rattling with the engine running, not from me shaking it. It's supposed to close shut at idle aka when engine vacuum is high, but it sounds like it's having trouble.
#564951 - 06/07/05 09:48 AM Re: PCV valve rattling?
sanitarium16 Offline
Loc: Long Island, NY
Buy a new PCV Valve. They're cheap, only like $5 bucks.
#564952 - 06/06/05 10:14 PM Re: PCV valve rattling?
Drew99GT Offline
I reluctently ordered one from the dealer. 7 buckeroonies. Oh well, least it's metal. Every other aftermarket one is obviously made by the same manufacturer and they're all plastic.
#564953 - 06/06/05 11:06 PM Re: PCV valve rattling?
kenw Offline
Loc: Houston
good deal, most of the aftermarket ones run $10. but the innanrds on the plastics ones (the one or two I've taken apart) were metal, just the outer shell was plastic.
The OEM on my 93 camry was plastic as was the replacement I got (for $10), i recently replaced it with 180k+ on the odo. Still seemed to be ok, but I just thought it might be due....
#564954 - 06/06/05 11:50 PM Re: PCV valve rattling?
Drew99GT Offline
$10? Yikes. The Fram I bought was around $3. Once the new one gets here, I'll take the Fram apart and see what the deal is.
#564955 - 06/06/05 11:59 PM Re: PCV valve rattling?
NewGuy Offline
Loc: North Carolina
I replaced the PCV valve in my wife's car with an aftermarket PCV valve and it gave horrible results. Start-ups and idle was rough, plus it began using oil for the first time. I tried a store brand PCV from both Autozone and Advance Auto Parts. Both rattled when you shook them and they were both new...but they both performed horribly.
I bought a $7.50 Motorcraft PCV valve from the Ford Dealership (came with a grommet) and it fixed everything. Start-up and idle are very smooth and oil usage is zero.
If I ever have to replace a PCV valve in another car I will use one from the dealer.
#564956 - 06/07/05 06:56 AM Re: PCV valve rattling?
Hirev Offline
Loc: Oregon
I totally agree with you. The rattle test does not show the entire picture. The OEM PCV valves have solved rough idle problems for me more than once. I no longer waste my money on aftermarket PCV valves. Even if you Lucky and get one that works right they still don't seem to last nearly as long as OEM. A rough idle is a very good sign you may have a problem with PCV valve.
#564957 - 06/07/05 08:10 AM Re: PCV valve rattling?
Drew99GT Offline
Well, I do in fact have a rough idle, so maybe I learned a lesson on this one. I've always thought PCV valves are so insignificant that any cheapo replacment'll do. Guess I'll add PCV to the short list of dealer only parts to buy. For me, this includes wires/cap/rotor, air filters sometimes, and Toyota red coolent.
#564958 - 06/07/05 08:18 AM Re: PCV valve rattling?
Gary Allan Offline
Loc: Pottstown, PA
It's supposed to flutter at idle. It basically is a regulated manifold leak. It opens ..bleeds off vacuum ..closes ..a constant cycle at idle. When you're going down the road ..it drafts in parallel with the throttle body and induces proportional flow depending on throttle position. All that it's missing is a throttle butterfly.
This is normal. They also, IIRC, don't truly close. There's supposed to be a curved metal spring (think mini-leaf) at the seating area. It will close upon backfire ..but bleeds some vacuum even when closed. You should be able to test this with your new one by blowing backwards through it.
#564959 - 06/07/05 08:39 AM Re: PCV valve rattling?
TallPaul Offline
Loc: By Detroit
