hi
I have a 1997 Olds LSS w/3800 "K" . This engine has about 182k mi on the clock.
Until I decided to install another set of NGK Iridiums, there never was a single instance of misfire.
Within 24 hrs, on cold starts, a SES (misfire #4) would occur.
I elected to install a new set of plugwires.
Again, withing 24hrs, another SES on #4. Thinking that I may have a bad plug on #4, I installed a new NGK. The "old" one looked fine
This time, I swapped in a new coil pack for the offending cylinder, but again, the next morning brought SES #4.
I used four bottles of Techron, one each tank full for the first two bottles and the final tankfull was with 2 bottles of Techron.
The next day seemed to bring relief, esp after a 460 mile drive. But the next morning after, another SES #4.
I then installed a new injector for #4, but still...the same SES #4.
Once the engine has been driven and underhood temps are up, all roughness seems to be virtually gone, and never a SES at load or warm operating temps.
The SES only occurs when the engine cools down, and you are ususally at idle. The roughness is apparent at this time.
Any help would be appreciated
[ April 15, 2005, 09:19 PM: Message edited by: lght1 ]
