My 3800 S II has a "acoustic engine cover" which is, in essence, a fairly heavy-gauge plastic "cowl" that covers the entire intake maniford and the front valve cover. It seems heavy ( ie thick) enough to have some heat-retention properties. I was wondering if it would make sense to remove it during the warmer months to allow the engine to shed heat more quickly/efficiently. Is this likely to have any positive effects on performance?
