I was wondering if someone can tell me what is the lube part of the 'lube and oil change'? what do you do? can it be diy? can someone tell me how to do it? i have an '04 civic vp. i'm doing my own oil changes so i don't know what to do about that.
Bingo.quote:
Originally posted by White 03:
I doubt most oil change places do anything for the lube part of the lube and oil change.
This is a little off. Plenty of "modern" cars and trucks still have grease fittings. And the "stupid" steering system you are referring to called recirculating ball steering, something BMW and Mercedes still use. Balljoints are used on all double-wishbone suspensions. They are not only used on trucks, but on most race cars. Far from stupid, these are one of the best suspension designs.quote:
Originally posted by cryptokid:
youre civic is a modern car and therefore doesnt have anything to lube besides the locks and hinges.
old fashoned cars and trucks has balljoints and stupid steering systems with things called pitman arms. these all need occasional greasing.
I stand corrected! You and the crew at Q-Lube must have actually been satisfied from doing a good jobquote:
Originally posted by srivett:
When I worked at a QLube (Quaker State --> Jiffy Lube later on) it was my job to lube the doors. I remember once when a guy in a K-Car had to open his door, the screech sounded like some kind of wounded animal! A few shots of ATF/10w30 in a pump bottle fixed it. With those particular cars you have to dig out a little hole to spray the oil into. I bet their neighbours were pleased just as much as the owner.
So yes, we do lube the doors. Lubing the suspension is hit and miss. The guy is under the car looking forward so he won't be able to see some of the fittings. Experience will tell him where to look but he doesn't know the car as well as many owners. Let's pretend there are 1000 different models in a given area, how will he remember them all?
Cheers, Steve
i guess you misunderstood me. i never said balljoints are a bad thing. infact most mcpherson struts use a balljoint under the strut to make the strut to the a arm.quote:
Most newer cars have machperson struts up front and a multilink in the back. These components could have grease fittings, but most manufacturers leave them out.
-T
