quote:
"Rotor Seasoning for Street or Light Track Applications
The first step in preparing the brake system for duty is to “SEASON” the rotors. The most visible effects are that of burning the machine oils from the surface of the iron and establishing a wear pattern between the pad and rotor. The most complex task it performs is that of relieving the internal stresses within the material."
"Bedding brake pads has a couple of important effects. The friction material in semi-metallic pads is held together by an organic binder, usually a type of phenolic material. As the pads get hot, the binder boils, and burns, from the top surface of the pad. Once this burning or “Bedding” takes place the friction material makes proper contact with the rotor."
"Bedding Metallic or Carbon/Metallic Pads - (NEVER DRAG the brakes)
Note: Never “Bed” pads on rotors which have not first been “Seasoned.” Always allow a substantial coast down zone when bedding pads that will allow you to safely drive the car to a stop in the event of fade."
