First, the vehicle is a 1993 Caprice 9C1 with the L05 engine (TBI 350). 207k currently. Finishing up my final (second) ARX rinse with GTX 5W-30.
Second, the problem: Oil pressure drops (on the gauge) under hard acceleration, generally not until higher rpm. Free revving in neutral will not do it. Furthermore, if I apply the brakes to keep the car at a steady speed but floor the gas, the oil pressure also will not drop. The car has to be accelerating. But before you say it's the pickup (pump being starved), there's a twist - if the oil level is a quart or more low, the pressure won't drop. Now that's curious. A final condition is, it won't drop when the oil temp is low. Only when the oil heats up and thins down does it begin to show the problem. I am going to try a heavier weight oil, like M1 0W-40 or GC (see below).
I made two movies about a year ago. The first is with the car having around 4 quarts in the crankcase, give or take. The second is me shutting the car off and adding about a quart (I think I was running Mobil 1 10W-30 at the time) and repeating the test within 1 minute.
A quart low
Full crankcase
Finally, a little history of the problem. It all started when I changed oil filter adapters. I needed to change to a later year adapter with external cooling lines to clear a driver's side cat for the dual exhaust conversion I was planning (just got it done last week, too). After installing the LT1 oil cooler adapter, I noticed the pressure drop under the above conditions. Then I went back to stock. Same deal. Then I ordered a non-oil-cooler adapter figuring I'd just ditch ALL of the oil cooling. STILL does it. To this day, I am running no oil cooler at all and the pressure still drops.
Does anybody have a clue here? A couple things have come to my mind:
1. Rear main seal blow-by, occuring only under acceleration and only when the crankcase is full. I am finishing up ARX and the problem is the exact same. Plus, I'm not sure how realistic that is anyway (I'd be losing a lot of oil and I'm not).
2. Oil pump pickup. This WOULD have made sense, except that the problem does not occur when the oil level is a quart low. Kind of blows that theory out of the water.
3. Oil pressure sending unit. I ordered a new GM one to rule that out. Both the original sender and the new GM replacement show the exact same problem.
4. Some other weird electrical problem. Not likely an electrical problem is sensitive to oil level.
5. Crank walk. My crank could be walking back on hard acceleration, blowing a lot of the oil pressure right back into the pan. Again, this would explain adequately except the problem does NOT occur with 4 quarts or less oil in the crankcase (5 is the right amount).
I believe I also have a severe pressure loss under very hard, extended braking (like a full ABS stop from 70mph or more) but I do not know if this is affected by the oil level in the crankcase. Haven't done any testing there, as I've been more concerned about oil pressure at high rpm/high load.
When the ARX rinse is done, I am switching to an xW-40 oil. Most likely M1 0W-40 or possibly GC 0W-30. A guy on a Camaro forum claims he fixed this problem in his car by switching to a 40 weight. That may fix it or at least help.
If there is anything else I can answer or clear up, I'd be glad to. It makes me afraid to beat on the car when I see that gauge dip below 30psi at high rpm, especially when it started at 45. Sometimes I wonder if I'd just be better off not seeing the gauge and playing ignorant...
A quart low
Full crankcase
