I know that driving without a muffler (on certain cars) can reduce back pressure enough to actually reduce engine performance, but can driving a car without a muffler cause engine damage? Thanks.
This is a myth. Back pressure is not desirable. If you put a 3" exhaust on a stock Honda Civic the drop in torque is due to improper tuning, not reduced backpressure. If your factory exhaust is 2" and you straight-pipe it (no cat or muffler) with 2" pipe you will see a power and efficiency gain across the entire rpm range. This may be small gain though if the exhaust is designed properly to begin with.quote:
Originally posted by Yuk:
I know that driving without a muffler (on certain cars) can reduce back pressure enough to actually reduce engine performance.
That's right! And well put.quote:
Originally posted by rpn453:
This is a myth. Back pressure is not desirable. If you put a 3" exhaust on a stock Honda Civic the drop in torque is due to improper tuning, not reduced backpressure. ...
I've heard of that, but I just can't visualize how the slightly cooler and denser exhaust gases cause a restriction. Can you explain that aspect any further?quote:
Originally posted by mechtech:
The problem is really with a larger diameter aftermarket exhaust, or free flowing muffler, CAUSING restriction by the more rapid cooling and contraction of exhaust gasses downstream. This causes a restriction until the heat/velocity are increased. This is why often there is a loss of low end power when opening up the exhaust.
You may notice that some race cars, after they are run, cap the exhaust in some way. Without a muffler in the way, air can enter the system as the engine cools and warp exhaust valves. I would expect that to be a potential problem with a street car with no muffler.quote:
Just to be clear:quote:
Couldn't that happen even with a muffler?quote:
