The 94-96 b-body LT1s had 10:1 with iron heads and the base Caprice motor a 4.3L version of the LT1 had 9.8:1 again iron heads, the LT1 will routinely have a cranking compression of 200+psi even beyond 100K. To make this even more unbelievable all that on 87 octane
, reverse flow cooling and a stock 180stat plus good injection and ignition control with duel knock sensors. I can prove all that if you like. The aluminum head versions of this motor came with 10.4 and 10.8 depending on which set of aluminum heads the LT1 or LT4.
mechtech, I do understand your points on engine temp and heat, this is exactly the same reason why iron heads should be better than aluminum, because they hold in heat better, but there are other factors that have to be considered and every application is different. As to
quote:
No manufacturer puts in 180s.
This is why I do my own work, mechanics have to know about a huge variety or cars and because of that can miss important details if they become too sure they know everything. I say with absolute certainty that I know this application better than you and better than most of the people who built it, it is my one bad habit(at least the wife thinks it bad
) and the thing that brought me here.
Oil temps get warm because of an in rad. oil cooler right at the hot inlet, and my warmup is fine with adequate heat in sub-zero weather rarely even requiring the second speed on the fan and that only for defrosting.
I actually do have a new 180 I plan to try again, and have dynoed the car as is so maybe I should try again after the 180 goes back in wont be a very exact test given neither try will be dialed in perfectly. As another interesting note I yanked the 4.3L V8 from my car at 110K, had the stock original 180 and dexcool for the first 96K then the 160, I swapped it for a 5.7l not due to internal problems, there is crosshatch left in every cylinder, so the low temp can't be too bad for the motor, this is downright common for the LT1s, just today a guy on one of the forums found the same thing on his wagon LT1 with 130K he too is modifying not repairing. If anyone is in the area and wants to see that old block sits in my garage.
