MC FL-820S C&P Coming
by BlueOvalFitter
05/02/16 12:11 AM
Creeping and Thickening
by camrydriver111
05/01/16 11:53 PM
Ariens B&S 17.5 o/c w/MK additive
by urrlord
05/01/16 11:31 PM
Question about grease for exmark mower
by Jetstreamz06
05/01/16 10:27 PM
Grease on door seals and glass
by JHZR2
05/01/16 10:12 PM
15k miles on Fram xg6607 2011 Mazda 2
by micmac
05/01/16 09:53 PM
2001 Mazda Tribute atf
by urrlord
05/01/16 09:43 PM
Bought a 21..95 Lawnmower battery at O'Reiily's
by andyd
05/01/16 09:20 PM
How do you feel about castrol edge 0w30 for a z06
by Jetstreamz06
05/01/16 08:33 PM
04 Mercedes c230 any good
by barkingspider
05/01/16 08:29 PM
Best spark plugs?
by jk_636
05/01/16 08:13 PM
Recoil, .380 versus .32?
by bobbob
05/01/16 07:47 PM
stydel311, jackadf, rlb4, apenland01, 2ManyMiles
57767 Registered Users
32 registered (Bill_G, BlueOvalFitter, carlprop, bobbob, B320i, boulderdentist, 2 invisible), 821 Guests and 315 Spiders online.
57767 Members
66 Forums
248338 Topics
Page 1 of 2 1 2 >
#552664 - 07/03/04 05:27 PM How to use an impact wrench?
Ken4 Offline
Loc: Singapore
I recently bought a 2hp air compressor and an impact wrench. Im not too sure how to use the impact wrench. Am I supposed to push the impact wrench hard against the lug nut for the impact to work properly? What is the 1-2-3-4 setting for? Dont laugh but I cant seem to get my lug nuts out using the impact wrench. [Duh!] The compressor is rated at 8 bar & 7.3cfm. The impact wrench says min 80psi & 4cfm. [I dont know]
#552665 - 07/03/04 07:03 PM Re: How to use an impact wrench?
eljefino Offline
Loc: ME
Is it a cheezy 250 ft/lb Campbell Hausfeld wrench? I have one and it doesn't do much. [Roll Eyes]
#552666 - 07/03/04 07:06 PM Re: How to use an impact wrench?
dkcase Offline
Loc: Suburban St. Louis
I have a compressor / 30 gallon receiver tank I have had for a long time. I haven't had success with an impact wrench for lug nuts.
I think it is because I have a pretty long hose on it and have too much pressure drop at the wrench, but I haven't tried to shorten it. Maybe I will as I get older and less fond of using the breaker bar.
Sounds like the numbers are a pressure adjustment, to allow you to dial down to less than full pressure.
It should work when applied normally to the nut, not necessary to press for any clutches or anything. Does it sound like it is impacting -- hammering -- when operated ? Or is it stalled, with just air exhausting ? If it's new, maybe it's broken ?
You should have a special socket for impact use -- thicker, malleable, less likely to fracture.
I may run the nuts on with the impact, but I always tighten to the final value with a torque wrench anyway.
#552667 - 07/03/04 07:25 PM Re: How to use an impact wrench?
Chris142 Offline
Loc: apple valley, ca
Ya the #s are the torque regulator. #4 being the highest setting.
I have that same wrench and it really impresses me. It has absolutly no problem with lug nuts. One squeeze and Wiiiiiiinnngggg! They are off!
I used mine thursday to set up a ring and pinon on a Dana#44 axle w/o any trouble.
I think maybe you don't have enough air pressure, too small hose or have the torque turned down.
How much air pressure do you have?
#552668 - 07/03/04 07:28 PM Re: How to use an impact wrench?
Gary Allan Offline
Loc: Pottstown, PA
One would assume this is for "torque limiting". Try 1 and then 4 on your lug nuts. If you have a decent FT/LB torque wrench ...determine what the lug nuts are torqued to (the last impact that applied them). This may be beyond the range of your wrench ..with your current air supply.
Most of the more powerful impacts are air hogs compared to your specs. At least that's what my (admittedly old) Snap-On catalog says. Most would outstrip the average compressor's ability to produce the appropriate air psi/volume if run continually.
#552669 - 07/03/04 07:37 PM Re: How to use an impact wrench?
Steve S Offline
Loc: East of IGO
2 hp is not enough to run an impact wrench. 10 cfm at 90psi is a good starting point to make the wrench work. The Ingersol Rand 231 is a great quality wrench for the money .
[ July 04, 2004, 10:41 AM: Message edited by: Steve S ]
#552670 - 07/03/04 07:56 PM Re: How to use an impact wrench?
Ken4 Offline
Loc: Singapore
Yeah it's a brand new 250ft-lb china/taiwan S$60 crappy impact wrench. I brought it to my neighbourhood tire shop and the kind boss tested it for me on his customers car, zzzoooomm, no sweat whatsoever. Then he showed me his store room where he kept his compressor, wow, it looked three times larger than my puny little one. I guess size DOES matter. Then he showed me 4 of his state-of-the-art impact wrenches, the smallest of which cost S$300+ and I really looked & felt like quality all over. I guess maybe my hose is too long (14 meters). I was wondering why my tire inflator tool only registered ~4barg (compressor gauge reads ~7.5barg). I will try shortening my air hose to see if that solves my problem. Here's a pic of my compressor.
[ July 04, 2004, 11:05 AM: Message edited by: Ken4 ]
#552671 - 07/03/04 08:31 PM Re: How to use an impact wrench?
seotaji Offline
Loc: USA
you need one of those old compressors with a belt connecting the motor and pump pulleys.
my friend has one and it's great no matter what cheap tool you attach to it. my dealership uses a substantially larger version of it.
#552672 - 07/03/04 08:43 PM Re: How to use an impact wrench?
Gary Allan Offline
Loc: Pottstown, PA
The output of the compressor doesn't matter (much). The psi limit and the size of the tank DOES. There are very few compressors (typically) that can run a decent air impact FULL TIME. Have you ever seen anyone run an impact FULL TIME? That's not how you "size" a compressor ..whether it's an air compressor ..or an airconditioning compressor. You do it based on typical demand. If you can run an impact FULL TIME ...you're wasting energy since you will have more "start up" current demand per cfm delivered under typical use (single or two bay setup - not a dealership) You don't use a 150 hp boiler to heat your house. Same with oversizing an airconditioning system (a very common mistake).
You need to "provide" xxx cfm @ xxx psi for the duration of the "use". This doesn't mean that your compressor has to fit your tool...just your reserve capacity. It's not like you're using a jackhammer on a contruction site.
Most of our compressors (not cheap) were all twin piston units set up for 135 psi ..the typical output (for the pulley/motor) was about 8-10 cfm since the typical "duty cycle" of anything we ran off of it was so short.
Shortening the hose will help ..but getting a bigger one will do the same thing. We used garden/heater type hose (off of a big spool) for most of our long distance air pump applications. This allows you to disapate less pressure over the resistance of the hose due to distance.
[ July 04, 2004, 11:53 AM: Message edited by: Gary Allan ]
#552673 - 07/03/04 08:55 PM Re: How to use an impact wrench?
cryptokid Offline
Loc: palm beach
dude no joke i have that exact same compressor only with a larger tank, and i have that exact impact wrench too.
the way i use it is i set the compressors air regulator to 120psi and the impact wrench to full power, i forget if its 1 or 4 thats full power, but anyways i never met a bolt or nut i couldnt get lose with that thing except my 350ftlb cv joint bolts which reuire me to STAND on the breaker bar.....
when you are tightening nuts and bolts set the impact to the lowest setting and reduce the air pressure on the compressor to around 50psi, this is good for quickly putting lugnuts and such on, but still leaves them lose enough to be properly torqued down by a torque wrench later.
i dont think the hose length has anything to do with it. air has little resistance to the small lengths we use, my air hose is 50 foot long and doesnt have any pressure drop.
#552674 - 07/04/04 09:12 AM Re: How to use an impact wrench?
Eddie Offline
Loc: Florida, Cape Coral
I have used 12gal 5hp and now a 4 gal 3hp compressor and can remove wheel lugs easley IF they were not over torqued. First thing to check is that the air regulator is set for maximum pressure(125 psi?). Next make sure the impact wrench is set for max pressure as some have an adjustment. Impact wrenchs also need run-in time needed to develope max torque. In addition:use some impact wrench tool lub oil which helps seal and protect the vanes. let us know how you make out.
#552675 - 07/04/04 09:15 AM Re: How to use an impact wrench?
Eddie Offline
Another thought is that the air hose inside diameter is important if your using a 50 foot hose. I use a 3/8 and 1/2 inch for runs over 50-100 feet and 1/4 inch for my 20 foot runs.
#552676 - 07/03/04 11:58 PM Re: How to use an impact wrench?
tom slick Offline
Loc: Central Coast, Calif.
most impact/air tools require 3/8" hose as a minimum, 1/4" as a short "whip" might be ok but even it will hamper performance.
for your small compressor i recommend turning the regulator up as high as it will go, make sure you have a 3/8" (9mm?) air hose and test each of the setting on your air gun to see which will give the most torque.
[Off Topic!]
i own an ingersoll rand "thunder gun" and although it looks and sounds neat when you first get it, the loudness of it get annoying after awhile. it is basically just one of their other comperable guns with no muffler (yes air tools have mufflers) which makes it louder and faster and more "racer" like. it is a fine tool and has a ton of power and speed, but they make others for the same price that are lighter, quieter and just as strong.
#552677 - 07/04/04 12:18 AM Re: How to use an impact wrench?
labman Offline
Loc: Nothern USA
Any air tool requires a certain volume at a certain pressure. Even a very small compressor and tank can run the biggest tool for a short period if the air can get there. An impact wrench should loosen a lug nut in seconds. With a small compressor, it may be a while until you can do the second one. Diameter of the hose is critical. I am not sure if air works the same, but a 3/8'' hose will supply up to 7.6 times as much water as a 1/4'' one. A hose that is half as long will have half the pressure drop.
#552678 - 07/04/04 12:46 AM Re: How to use an impact wrench?
JohnBrowning Offline
Loc: USA
Set the dial on the gun to 4 wich is the highest setting. Set regulator to 8 bar!!! You have to oil the gun before use. Their should be an oil port pluged with a screw. You also have to add a bit of oil to the air intake nipple side of the gun. Impact sockets are best but standard sockets will work just fine.
You have to push on it only hard enough to keep it from jumping off of the lugnut as it impacts and trys to torque out of your wrist.
P.S. Your compressor is on the anemic side but should be able to get the job done. THat little compressor sounds like a pan cake compressor for running roofing equipment.
Page 1 of 2 1 2 >
