I have been told opposite things about the value and danger of putting teflon tape on the threads of my brake bleeder screws. I have read in Popular Mechanics and been told by other people that putting teflon tape onto the threads (in order to prevent any air being drawn into/out of teh system when bleeding) that the teflon can come apart and flow through your system and eventaully clog ABS valves and whatnot. Other have said it is ok and that since the fluid is only applying pressure one way it shoudln't matter.
But wouldn't the suction of the master cylinder returning to normal position when you let off the brakes evenutally move the pieces of teflon up?
BTW we are bleeding with a mighty-vac thing that you hook up to an aircompressor and it sucks out the fluid.
