Now is the time to stock up at $0.94.
They are phasing out the winter formula for the summer blend which contains less alcohol and more water.
The winter version has more alcohol/cleaning power.
If you want you can dilute the winter mix for cheaper fluid (since it reccomends 1 part winter mix with 2 parts water for the summer months regardless). I'm using 1:1 winter:water mix.
Just lettin ya know.
