quote:
Originally posted by dickwells:
Can anyone help me get a copy of the TSB above? It is for the distributor problem I had with my 02 4.3 Silverado, something about corrosion in the distributor. Will be glad to reimburse any expenses, Thanks, RW
Bulletins for 2002 Chevy Truck C 1500 P/U 2WD V6-262 4.3L VIN W SFI
General Recalls
TSB Number Issue Date TSB Title
1. 99066F MAR 03 Campaign - SCPI Warranty Extension
Service Bulletins
1. 03-02-36-002 JUL 03 Steering - Revised Service Procedures
2. 03-09-41-003 JUL 03 Restraint System - Proper Air Bag System Diagnosis
3. 01-06-01-011A JUL 03 Engine - Oil Consumption Information
4. 01-01-39-003A JUL 03 A/C - Catastrophic Compressor Failure Debris Removal
5. 01-01-38-006B JUL 03 A/C - R-134A System Flushing Procedure
6. 03-08-44-011 JUN 03 Audio System - Tweeter Rattles in Front Door(s)
7. 02-06-05-003B JUN 03 Exhaust System - Low Rpm Moan/Vibration
8. 00-08-42-010A JUN 03 Lighting - DRL Bulb Replacement
9. 03-03-08-002 JUN 03 Suspension - Rattle/Squeak From Front of Vehicle
10. 99-07-30-022A JUN 03 A/T - Shift Stabilization/Tow/Haul Mode Feature
11. 03-06-04-030 MAY 03 Fuel System - Possible MIL ON/Driveability Symptoms
12. 00-05-23-005B MAY 03 Brakes - Accelerated Right Rear Inner Brake Pad Wear
13. 01-08-97-001A MAY 03 Auxiliary Equipment - Homelink (R) Transmitter Testing
14. 99-08-52-005A MAY 03 Keyless Entry System - Operational Characteristics
15. 03-07-30-007 APR 03 A/T - Apparent Delayed Gear Engagement
16. 03-07-29-004 APR 03 M/T - Operating Characteristics
17. 03-03-10-001A APR 03 Tires/Wheels - Tire Slowly Flattens/Vibration
18. 99-01-39-007B MAR 03 A/C - Automatic A/C Functional Description
19. 03-01-38-001 MAR 03 A/C - System Sealers/Leak Detection Guidelines
20. 00-05-22-002B MAR 03 Brakes - Rotor Service Guidelines
21. 02-08-42-001A MAR 03 Lighting - Polycarbonate Headlamp Damage Prevention
22. 99-07-30-017A FEB 03 A/T - Oil Cooler Flushing/Flow Check Procedures
23. 02-05-26-002A FEB 03 Brakes - Scraping Noises From Rear of Vehicle
24. 00-06-04-003B FEB 03 Fuel System - MIL ON/Rough Idle on Start-Up
25. 03-03-10-002 FEB 03 Hubcaps - Loose/Rattling
26. 99-08-64-016A JAN 03 Body - Weatherstrip Maintenance
27. 03-06-04-012 JAN 03 Electrical - Wiring Harness Inspection Recommendations
28. 00-02-35-003B JAN 03 Steering - Clunking Noise From Under Hood
29. 99-03-10-009A JAN 03 Wheels/Tires - Wheel Weight Usage
30. 01-07-30-042A DEC 02 A/T - 2-3 Upshift or 3-2 Downshift Clunk Explanation
31. 01-07-30-036B DEC 02 A/T Controls - DTC P0756 Diagnostic Tips
32. 02-06-03-006A DEC 02 Electrical - Testing Before Replacing Battery or Alt
33. 00-06-01-023B DEC 02 Engine - Balance Shaft Rattle Noise Explanation
34. 02-06-01-038 DEC 02 Engine - Knocking or Lifter Noise
35. 02-06-04-059 DEC 02 Engine Controls - Engine Runs Rough/MIL ON/DTC's Set
36. 02-07-30-032A NOV 02 A/T - TCM Fast Learn Procedure Requirement
37. 99-07-30-016B OCT 02 A/T - Intermittent Downshift/Slip/Cycling Diagnosis
38. 02-06-03-009A OCT 02 Battery - Charging/Information Tips
39. 02-06-03-010 OCT 02 Battery - Parasitic Drain Information
40. 02-05-23-004 OCT 02 Brakes - 'Reduced Brake Power' Shown on DIC
41. 02-05-22-004B OCT 02 Electrical - Trailer Brakes Applied With Headlamps ON
42. 02-03-07-002 OCT 02 Steering/Suspension - Revised Camber/Caster Adjustment
43. 02-07-30-004A SEP 02 A/T - Allison 1000(R) Grade Brake Feature
44. 02-05-26-001 SEP 02 Brakes - Rear Park Brake Service Kit Available
45. 02-04-95-001 SEP 02 Drivetrain - Revised Differential Overhaul Procedure
46. 02-08-49-007 SEP 02 Interior - Console Lid Hard to Open/Close
47. 02-08-46-011 SEP 02 Service Manual - Revised OnStar(R) VIU & VCU Replacement
48. 02-07-30-030 AUG 02 A/T - 1st to 2nd gear Shift Shudder
49. 01-08-66-005B AUG 02 Body - Pickup Box Reinforcement Kit Availability
50. 01-08-66-014A AUG 02 Body - Pickup Box Sheet Metal Fracture/Damage
51. 02-06-03-008 AUG 02 Charging System - Low Voltage Display ON/Dim Lights
52. 02-06-01-028 AUG 02 Engine - Crankcase Flushing Recommendations
53. 02-08-47-001 JUL 02 Body Control - Update of Some Control Module DTC's
54. 02-04-17-001A JUL 02 Drivetrain - Launch Shudder/Vibration On Acceleration
55. 01-08-64-014A JUL 02 Interior - Lock Lever Comes Loose From Door Trim Panel
56. 02-07-30-028 JUN 02 A/T - Serial Number/Site Code Locations/Identification
57. 02-09-41-001 JUN 02 Computers & Controls - DTC's Set When Replacing Modules
58. 02-06-01-026 JUN 02 Engine - Identification Information
59. 02-07-30-024 MAY 02 A/T - Cracked/Broken Case Diagnosis
60. 02-08-44-007 MAY 02 Audio System (XM) - Negative Impact of Vinyl/Cloth Roofs
61. 02-04-20-002 MAY 02 Drive Train - Revised Wheel Bearing Adjustment Procedure
62. 02-08-46-007 MAY 02 OnStar (R) - Caller Minutes Cannot Be Replenished
63. 02-08-46-006 MAY 02 OnStar (R) - Incorrect GPS Location During OnStar Call
64. 02-08-42-004 APR 02 A/T - PRNDL Display Dim for One Minute
65. 02-08-59-002 APR 02 Dash - Rattle From Center
66. 02-00-90-002 APR 02 Driveshaft Double Cardan Joint - Manual Update
67. 02-08-46-004 APR 02 OnStar System (R) - Cellular Error Messages
68. 99-08-51-007A MAR 02 Aluminum Wheels - Refinishing
69. 02-06-04-015 MAR 02 Engine - Intermittent No Crank/No Start
70. 02-06-01-008 MAR 02 Engine - New Prelube Tool
71. 01-01-39-005A FEB 02 Interior - Noise/Vibration With A/C ON
72. 99-00-89-019B FEB 02 Warranty - Parts Return Program Explained
73. 01-01-39-007 JAN 02 A/C - Loss of Mode/Temperature Control
74. 02-07-30-001 JAN 02 A/T - 4L60E/4L65E DTC P1870 Diagnostics
75. 02-02-35-001 JAN 02 Ignition Lock Cylinder - Revised Replacement Procedure
76. 00-00-89-027A JAN 02 Interior - New Odor Elimination Product
77. 01-02-118-001 JAN 02 Rear Axle - `QUADRASTEER'(R) Parts Restriction/Exchange
78. 01-03-10-012 JAN 02 Wheel Balance/Alignment - Labor Operation Guidelines
79. 01-01-38-013 DEC 01 A/C Compressor - Diagnostic Considerations
80. 01-07-30-041 DEC 01 A/T - Fluid Leak Diagnosis
81. 01-07-30-038 DEC 01 A/T - Poor Performance/SES Lamp ON/DTC P0757 Set
82. 01-07-30-043 DEC 01 A/T - Slipping/Missed Shifts Diagnostic Tips
83. 01-08-46-006A DEC 01 Onstar(R) - Antenna Coupling Revised Procedures
84. 01-03-10-011 DEC 01 Tires - Sidewall Damage
85. 01-08-97-002 NOV 01 HomeLink(R) Transmitter - Programming Difficulties
86. 01-07-31-002 NOV 01 M/T - Improved Clutch Bleeding Procedure
87. 01-08-44-014 NOV 01 Radio - Erratic or Intermittent Operation
88. 01-08-44-008A NOV 01 Tools - PDI Antenna Mast Installation
89. 01-03-10-009 NOV 01 Wheel Nut Covers - Loose/Missing
90. 01-07-30-029 OCT 01 A/T - Core Return Product Feedback Form
91. 01-07-30-030 OCT 01 A/T - Harsh 1 to 2 Gear Upshift Diagnostic Information
92. 01-08-49-017 OCT 01 Center Front Floor Console Lock & Key - Availability
93. 00-06-04-011A OCT 01 EVAP System - Monitor Strategy
94. 01-00-89-015 OCT 01 PDI - Dealer & Production Installed Accessories
95. 01-08-64-015 OCT 01 Side Access Door - Squeak or Scraping Noise
96. 01-03-10-007 OCT 01 Spare Tire - Lowering Information
97. 01-08-51-003 OCT 01 Vehicle - Interior/Exterior Anti-Corrosion Materials
98. 99-04-20-002A SEP 01 Driveline - Clunk Explanation
99. 01-00-89-013 SEP 01 RKE Transmitter - Correct Use of Labor Operation R4490
100. 01-01-39-003 AUG 01 A/C - Screen Filter Kit
101. 01-08-46-004 AUG 01 Cellular Phones - Operating Characteristics
102. 01-08-51-002 AUG 01 Door Edge - New Protection
103. 01-00-89-011A AUG 01 Technical Assistance Form - New
104. 01-08-44-006A JUN 01 Audio System - Clearing `CLN' Message From Display
105. 01-00-89-010 JUN 01 Diagnostic Worksheet - Usage
106. 01-09-40-001 JUN 01 Front Seat Belt - Retractor and Buckle Replacement
107. 01-09-40-002 JUN 01 Seat Belt System - Collision Replacement Guidelines
108. 01-00-89-011 JUN 01 Vehicle - Technical Assistance Form
109. 01-00-89-009 MAY 01 Key/Key Number/Security Chip - Replacement
110. 01-00-89-08 APR 01 Service Information 2000 - Campaign Access
Don't see it...
