You'll need to do something. I've noticed that a gas engine generator modified for use with propane has about 20% less output...quote:
Originally posted by ZmOz:
This is going to be to run various electrical eqipment in a field. It will be turning a 60hz 50kw generator that spins at 1800 RPMs. I was planning on gasoline, but now I'm thinking about propane. If I built a stroked 4.7 liter engine, I could raise the compression ratio to arund 12:1...because propane is around 110 octane.quote:
Originally posted by eljefino:
Is this going to be standby or continuous use? Running gasoline, propane, or natural gas? What climate? Can you get a deal on fuel (no road tax, etc?)
Do you expect 60hz current? Will you be doing an alternator/inverter setup or some sort of gearbox so the generator innards naturally turn 1800 or 3600 rpm? (adjust for lands of 50hz.)
Just curious.
