Where are the best points on a unibody front wheel drive car (94 Toyota Corolla) to jack up the car and then put it on jack stands? Obviously behind each front wheel and in front of each rear wheel under the rocker panels where the factory scissor jack fits. But then where do you put the jack stands? I've heard mixed feelings about using all the suspension cross members under the front of the car.
Reason I ask is I just had the B*stard up in the air to work on it for the 1st time since I got it. I tried on one side using the exact spot for the scissor jack with my floor jack and then placed the stand a little behind the jack under the rocker panel. That clearly pushed my floor pan up!!! Doh. So on the other side I just put the jack a little further under the car next to the lip that your supposed to use for the scissor jack. That just bent the crap out of my floor pan
I bashed it back down with a rubber mallet so my floor is flat again in the passenger compartment. Man I'm pissed at myself, but the stupid haynes manual doesn't even tell you proper floor jack points, just the spots where the scissor jack goes for changing a flat. Everyone knows you can use those, but where else? Thanks guys.. just had to vent a bit. Any suggestions would be much appreciated. Oh, and do you think I damaged the frame or anything by jacking where I did?
[ May 26, 2003, 06:20 PM: Message edited by: Drew99GT ]
