Which is a better situation:
1. Having an engine rev to about 1800 rpm at startup, and drop down to a normal 700 rpm idle?
2. Having an engine rev to about 900 rmp at startup, and drop down to a normal 700 rpm?
The higher revving engine (at startup) will get oil pressure faster, but will also be running faster before the pressure builds.
The lower rpm engine will take more time for oil pressure to build, but will be running slower before the pressure builds.
Which startup situation creates less engine wear, or does it really matter.....?
