OK, I am officially freaking out! Drained the oil on my fresh (250miles)455 with Comp Hyd Roller camshaft and took a nice long look at the oil. I realize that during the break in process things get seated and polished but the entire pan of oil has the appearance of metallic paint. Dark brown and sparkly! Not happy, especially since I changed the oil and filter after the first hour of break in and this oil only has the 250 driven miles on it . The particles are obviously micronic since they are suspended in the oil and the filter had only a small amount of debris in the bottom. The sparkly oil is not affected by a magnet so I suspect it is non-ferrous in nature. It also leaves a swirly "tracer" when I drag my finger thru the drain pan. Geez, this seems like a freaking lot of metal!! Also, there were no unusual engine noises during the drive time. Compression is 9.5:1, timing is set at a conservative 9 initial with 20 mech, 8 degrees vacuum adv.
Any thoughts or comforting advice? Before I severely beat my engine builder, I have sent oil out for a spectral analysis. Anyone out there had a similar experience? How bad should break in oil look? BTW, the oil was 15w40 Rotella T.
Kevin
Kevin
