I haven't tried changing brands of fuel yet, but then again this car has always run the same fuel and gotten better mileage in the past.quote:
Originally posted by ZR2RANDO:
Usually a clogged filter (any kind-oil/fuel/air..) shows up only at high flow rates, low flow rates still flow enough. If the fuel filter was really clogged you would notice lack of response at high rpms, same with catalytic converter, any clogging would be noticed at higher rpms (would give lower mpg due to exhaust gas resistance).
Winter driving always gives me slightly less mpg and slightly better driveability---cold air expands more in the cylinders.
Some vehicles burn some brands of fuel better than other brands too.
good luck
Based on the above post my problem can't be catalytic or a clogged filter, because the car runs great and still feels strong (as 106hp can) at upper rpms. No power loss.
And as I've said before, the plugs I pulled out looked good, not fuel soaked at all. It's almost as if my wife is driving around in 3rd gear (although I know she is not)
