a friend asked me to do an oil change on a 1999 volvo with a cummins n14 430hp non-turbo engine. what oil,fuel,air filter part no.s do i need? also, what grade and quantity of oil do i need? thanks!!!
survivor? so is this engine turbo'd? according to my friend, he says it's not. but i think he may be wrong.i know of a napa near my house where i will probably go to get the filters. are the napa brands good too?quote:
Hi Dave,
this is a true "survivor" in the Cummins heavy engine range! Not like the later Signature series!!
All are turbocharged/intercooled
I myself have a 95 Volvo with a Cummins N14 set at 500HP. The N14's usually all used the same filters. Cummins owns Fleetguard and they are the ONLY filters I will use on my N14 except for the Oilguard bypass that i installed. The two oil filters that fit are the LF3000 (standard stratapore with built in bypass) and the LF9009 extended life filter which is also Stratapore and bypass combo but uses a venturi stle outlet that allows the ultra clean bypass oil to be sent to the bearings instead of being dumped back to the sump. I personally use the LF9009.quote:
