Background: The truck has about 100,000 KM on it, and it was run on 15w-40 Quick Lube dino at 10-12,000 KM drains as suggested by the oil life monitor for all of its life.
Truck is located in Tornoto
I plan to:
1) Change Full-Flow Filter and add 2 bottles Auto-RX to the existing oil to clean-up residue buildup, residue wear metals, and additive clash. Run for 2400KM.
2) Rinse with 15w-40 conventional for 5000KM.
3) Change oil and filter to Amsoil AME 15w-40 (New Formulation), and install Amsoil BMK-17 Bypass Filter (SDF-26 FF and BE-100 Bypass) and peacock valve.
4) Change engine air filter with a new paper air filter and replace PCV valve.
Follow Up:
1) Take oil sample every 20,000 KM (about 6 mo)
2) Install a NEW SDF-26 Oil Filter, BE-100 Bypass Filter, NEW paper air filter, and NEW PCV valve every 40,000 KM. (About 1-yr)
So, what do you folks think of my plan?
How long do you think this oil will last?
The truck sees a lot of highway driving.
Michael
I plan to:
Follow Up:
Michael
