I've done some searches around here regarding the use of diesel motor oils in gasoline engines, and I'd like to make an attempt at summing up my findings, and then have you tribologists correct me and/or expand... is that okay? This is my first post here, so I hope you all will bear with me.
I just bought a 1983 F250 (8600lb GVWR) 4x4 with a 460. It has 98,000 miles on the original engine, and when we took the valve covers off to replace leaking gaskets, we found a very clean engine. The original owner had used Pennzoil 10W30 and Fram oil filters, and had changed them consistently and regularly. It has great compression and doesn't burn oil, at least no more than a healthy engine should.
I've always been a Chevron Delo and Shell Rotella fan, so I have been thinking of using those oils. The only problem is that both are hard to find in 10W30. Would I be doing this engine a disservice by switching to 15W40? I am concerned about oil circulation upon startup, and getting oil to all the bearings as quickly as possible.
I live in SoCal, so we don't get truly "cold" weather here, but even so, my belief has long been that most of the wear on an engine is upon startup, before the oil is fully circulating at the proper pressure. In fact, I used to use Delo 400 Synthetic 0W30 in my vehicles, but I have gotten tired of special ordering it and driving 50 miles to get it.
Or, should I just stick with what has worked for 22 years and use Pennzoil 10W30?
Sorry this is so long!
