Luchsea,
Any 15W-40 diesel engine oil with API Service Category CH-4 or CI-4 will work well for you. They all have the necessary anti-foaming agents in them. Some oils will work better. Chevron Delo 400, Pennzoil Longlife, and Mobil Delvac 1300S are all very good. Shell Rotella-T is adequate, but for the money, you can probably get better oil. The best oil for the cost is probably Schaeffer's #700 15W-40 synthetic blend, and it will give you easier starts and less wear in your cold winters. Also excellent, especially in the winter is Mobil Delvac 1 5W-40 synthetic diesel engine oil, but it's pricier and little if any better than Schaeffer's. Amsoil 15W-40 is also excellent, but pricey.
If you really want the best life from that engine, use a block heater in the winter...you'll have reduced wear on the cold engine as well as easier starts.
Oil filters?...OEM, Fleetguard Stratapore (made by Cummins and probably the best), WIX & NAPA-Gold, Baldwin.
Bypass oil filter?...pricey and may extend the life of your engine from 400,000 miles to, what?, twice that? The body will fall off the frame before the engine wears out.
Automatic transmission?...Add a Racor LFS22825 filter and change the ATF every 30,000 miles with standard ATF or every 60,000 with Schaeffer's #204S synthetic blend ATF or a full synthetic ATF.
Ken
[ August 22, 2003, 08:21 PM: Message edited by: Ken2 ]
