You know, the common assumption with BB Mopars is that you have to run a tight lobe seperation camshaft.
If you look at the valve timing comparison between a tight lobe sep cam and a wide lobe sep cam of equal duration, you will see that:
1. The overlap is much greater with the tight lobe sep cam. (the overlap "area" is what counts)
Valve overlap causes rough idle and poor low rpm performance.
Vacuume secondary carbs and power brakes do not like overlap.
And vacuume operated windshield wipers I guess.
The other event that changes is the intake valve closing point and "dynamic" compresion ratio as described in the above link.
I think the reason why BB Mopar guys go for the tight sep cams is to prop-up a small intake port with an early intake valve opening point.
Opening the intake valve early slows the intake port velocity at low and medium RPMs, making the signal to the carb weak.
Match that to a late exhaust valve closing point and you end up with overlap, poor low rpm intake port velocity, rough idle and poor carburation.
Now the intake closing point, give or take a little valve lash, and resulting dynamic compression ratio, I think is overplayed by magizine writers as the end all and be-all to the entire camshaft specs.
I suppose if that is all they know, that is all they can write about.
Achieving high intake port velocity with valve timing goes something like this...
Delay the intake valve opening point until the piston has moved down the bore a little causing a low pressure area in the cylinder.
The higher the compression is, the lower the cylinder pressure will be before the intake valve is opened.
Now slap open the intake (large) valve with an agressive lobe and a high ratio rocker.
Nascar FT lobes are good lifter and valve slappers especially with 2:1 rocker ratios attached to the formula.
The "late start" intake will cause a very high port velocity that will continue to feed the cylinder after BDC "ramming" the cylinder beyond 100% VE.
That is called the "late start better finnish" ram theory.
The above is the Reader's Digest 1.1 version.
[ December 05, 2003, 01:07 AM: Message edited by: userfriendly ]
