In the USA, "Hylomar" is the Permatex-licensed version of Hylomar's "universal blue" formuala.
Globally, Hylomar is a vendor like Loctite, and famous
According to Hylomar's website they have an anearobic (Loctite equivalent), aircraft-grade (high-temp, high-vibration, metal-to-metal
contact), advanced formula, as well as silicon and polyurethane sealants:
http://www.hylomar.com
What would you use to avoid the typical valve-cover and front-timing cover gaskets from leaking oil, esp. with high-detergent synthetics like Mobil 1 0W-40 or "German" Castrol Syntec 0w-30.
Hylomar, MB "gray" sealants, or something else?
Thanks again,
neil
[ October 05, 2003, 05:20 AM: Message edited by: rugerman1 ]
Thanks again,
neil
