Hi,
I would like to ask some expert opinion wether there is a direct relationship between oil leaks specifically hydraulic oil and contamination. Since oftentimes, an engineer will try to modify the strenght or material of the seal, however from what I know is that if there is leaks then there is ingression of contamination and water, hence, to me it sounds logical to say that with water, silicon and all sorts of contamination, and oil oxidation, this will accelerate the wear of seals and result is leaks, I would like to confirm this if there is direct relationship if the oil is dirty then system is more prone to leaks and if oil is maintained clean at certain ISO standards then leaks can be addressed to a minimum or not at all. I need this answer ASAP, hope you dont mind and thank you for allowing me to post this question
