Hey guys...
We've got a problem at work. About four of our Kenworth road tractors are beginning to have trouble with the Meritor (formerly Rockwell) 12 speed "Freedomline" automatic transmissions. These are straight 12 speed automatics, with no clutch pedal at all. (Pain in the arse on a hill at a red light, but that's another story).
The problem we're seeing is that a bushing that surrounds the shifting fork is galling and sticking on the fork rod. This causes the tranny to BANG into and out of gear, and sometimes it won't go into gear at all.
Meritor hasn't been of much help at this point. They have a "new and improved" bushing but supply is WAY behind demand.
I was wondering if there might be some kind of additive we might try in one of the trucks that is giving trouble. The current lube in the transmissions is a factory fill synthetic of some kind--not sure what. I was wondering if there might be something that we might add to the gear oil which could provide some sort of barrier lubrication to prevent the sticking of that bushing/fork.
Any ideas?
Not concerned about warranty issues at this time. The factory warranty doesn't specify that additives not be used. I've even thought of thinning the transmission oil a bit for winter use (maybe with a gallon of 15W40 engine oil or such) but am at a total loss for expertise at this point.
Dan
Any ideas?
Dan
