quote:
AMSOIL SG Oils are fully formulated with sulphur/phosphorous extreme pressure additives, antioxidants, rust inhibitors, and anti-foam agents. The SG Oil's thermally stable, extreme-pressure additive system forms a hard, iron-sulfide coating on metal components. This iron-sulfide coating prevents metal to metal contact under boundary lubrication conditions, reduces friction and protects components against shock loading and wear. The anti-oxidants increase the oxidation resistance of the synthetic base oils for long, clean lubricant performance. These oils protect against rust from water or process contaminants and prevent foaming, ensuring proper lubrication.
