Quote:
What CAT motor and what Allison transmission does your motor home have?
Any time you don't have cooling issues in a diesel pusher your doing good! Their notorious for poor cooling. What year is your motor home? It seems to me i see more failures in Low mileage Diesel's with ELC that has never been changed.
If you don't see more than 75,000 miles a year i recommend a 4-5 year max life span for ELC before a flush and re-fill with distilled water and Fresh ELC
CAT 3126B (7.2 L or 440 cu. in.) turbo, air to air intercooler pulling about 27,000-28,000 lbs. Allison 3000 series auto. I usually run the auto transmission in the economy mode that is selectable from the pushbutton transmission control panel (slightly lower RPM shift points) unless I’m in hilly country.
The CAT gets Mobil Delvac 15W-40 with CAT OE filters at 10,000 miles. The cooling system gets CAT’s long-life coolant with the extended service pack (changed by CAT at 40,000 miles). Air filter is changed when approaching the red range. Fuel filter will get changed this weekend along with the engine oil and filter. The chassis is greased with Shell Retinax. The hubs are oiled with Shell 90W gear oil.
Four 6-volt (series-parallel) deep cycle house batteries, two 990CCA 12-volt truck batteries (parallel), Onan 7.5Kw diesel generator with about 450 hrs, 2000 watt inverter, two 13.500 Btu heat pumps.
Belts, hoses and all other gear is like new. I paid $80,000.00 for the coach last September…..a pretty good deal, I believe.
The coach has only has 50,000 miles on it. It is a Holiday Rambler Endeavor 39 foot on a Freightliner chassis with a 1999 build date on the manufacturer’s nameplate, original Michelin tires. All the chassis components are in very good shape, brakes are antilock and work to perfection. The only complaint is occasionally, I must replace the 10-amp fuse for the turn signals. I suspect that this circuit’s current draw is exceeded especially if I use the turn signals shortly after starting the coach after a lay-up (slightly low battery voltage likely increases the current draw in the turn signal circuit). I will correct this by substituting LEDs for turn signal and side clearance/turn signal bulbs.
So far, excellent coach with reliable performance no oil leaks anywhere and very good mileage. I do have a light foot on the throttle.
This weekend, I need to check valve lash before changing oil.
You are correct, the rear engine motor homes with rear radiator placement (rather than side placement) can overheat especially with a tail wind. The secret is to carefully degrease and pressure wash the backside of the cooling system from the engine side. The CAT crankcase breather exits just at the lower portion of the intercooler. This breather does produce some moderate oil mist and can produce clogging in the lower portion of the intercooler and engine radiator lowering cooling capacity and causing high temperatures on the engine coolant temp gauge. The radiator and intercooler are clean along with the cooling fan. I am thinking of rerouting the engine breather however there is no evidence of any oil misting from this breather. I have seen no reduction of crankcase oil on the dipstick since 43,000 miles. I believe it is the Delvac that keeps oil where it belongs.
Any thoughts here?
