stingray427, I think you're a little too paranoid about using an unlicensed ATF in your GM. Licenses don't mean anything, other than that GM would recommend it, but as long as it is extensively tested and meets/exceeds all specs (Amsoil and Redline both meet/exceed the DexronIII-H spec that you require, Pablo has told you this about Amsoil many many times), then there is nothing for you to worry about.
Amsoil/Redline/Mobil 1/Royal Purple can all meet the specs without being licensed, but it must meet X-specs and pass X-tests (where X is a variable).
So dude, please just relax and quit asking the same question 2309572937410830124987259257 times.
