I'm in the process of flushing my power steering system in my Nissan Frontier and would like some opinions on what fluid to refill with. My owners manual states the following...
"Genuine NISSAN PSF, Canada NISSAN Automatic Transmission Fluid, DexronTM III/MerconTM, or equivalent ATF may also be used."
I've already bought some Prestone Power Steering Fluid from Wal-Mart in the red quarts bottles and know it is clear versus the red fluid in there now with 80000 miles on it. I'm assuming the factory fill is with ATF Dexron III/Mercon.....should I just take the Prestone back and get some Castrol ATF and keep it like factory fill?....or will the Prestone work fine in my truck and not cause problems like leaks, etc..?
Thanks!
Thanks!
