New Supertech jugs?
by dlundblad
06/26/16 06:16 AM
Fram ph3657 cut open
by jhellwig
06/26/16 05:07 AM
Don't discount coal for a long while yet...
by Shannow
06/26/16 03:10 AM
Decent Wireless Computer Headset?
by 99Saturn
06/25/16 11:41 PM
Need Fuel Pump Assembly for Camry
by Nick1994
06/25/16 11:36 PM
2015 Accord V6 VCM engine UOA 36,680 mi / 9812 OCI
by TNM1982
06/25/16 10:55 PM
Why did Toyota recommend a winter and summer oil?
by BrianApp
06/25/16 10:00 PM
Fram TG 7317 6k miles
by bbhero
06/25/16 09:57 PM
Sta-Lube Moly-Graph Grease
by JHZR2
06/25/16 09:20 PM
Dead battery locks me out of Altima!
by Tom NJ
06/25/16 08:56 PM
Second lawn mower blade
by greasegunn
06/25/16 08:11 PM
Echo weed trimmer - carb issue?
by ryan2022
06/25/16 07:13 PM
paul2005tb, Martyaus, carmelo, Shellman, SSO
58272 Registered Users
49 registered (BobFout, bbhero, alcyon, b1amgm47, car51, BigRalphie, 2 invisible), 966 Guests and 14 Spiders online.
58272 Members
66 Forums
250821 Topics
#525537 - 06/15/06 12:02 AM ATF cooler return line - which is it???
sky jumper Offline
Loc: Chicago
2k Honda Civic. in diag below, which "ATF cooler hose" is the return line? want to do the cooler line fluid exchange....
#525538 - 06/15/06 12:54 AM Re: ATF cooler return line - which is it???
ConfederateTyrant Offline
Loc: Morrow, Georgia
Not meaning to sound like a smart*** but pull one hose at a time off of the radiator. When the fluid comes out of the radiator, the line removed is the return line.
Though, if I had to take a guess, I would try the right (if looking straight at the radiator) line. I once heard that the return line is usually located higher up on the transmission, but I cannot verify that for all cars. Just disconnect it and turn the engine on for about 5 seconds and shut it down. Be sure to put a hose over it so it won't spray all over the place.
#525539 - 06/15/06 10:08 PM Re: ATF cooler return line - which is it???
sky jumper Offline
Loc: Chicago
so, to summarize:
1) disconnect either hose
2) have helper start engine, put into gear
3a) if fluid comes out the hose, the other one is the return line
3b) if fluid comes out the cooler, the disconnected hose is the return line.
4) connect discharge tube to the cooler outlet, and proceed with the fluid exchange.
got it.
#525540 - 06/16/06 04:24 AM Re: ATF cooler return line - which is it???
The Critic Offline
Loc: Walnut Creek, CA
Or, just drain/fill three to four times to accomplish the same effect.
You would've replaced > 85% of the fluid after four drain/fills, if not > 90%.
Beware of delicate cooler lines or ones with "rusted" fittings.
#525541 - 06/16/06 07:07 PM Re: ATF cooler return line - which is it???
That's right sky jumper, and The Critic's advice is good too. Drain and fill, drive for a week, do another drain and fill, and repeat 4-5 times and you should have nearly the same ratio as if doing a cooler line flush (based that on all of the forum post I have read about drain and fills on BITOG).
Your Honda more than likely has a drain plug, which makes the drain and fills MUCH easier. My car only has the pan and filter, which is not a fun chore to remove.
#525542 - 06/17/06 09:44 AM Re: ATF cooler return line - which is it???
unDummy Offline
Loc: RI
If you don't want to bother with 1/2 dozen drain refills, stick with the cooler line flush. But, you'll still need to do a drain/refill prior to starting.
Disconnect either ATF cooler line hose. Attach some hose to the disconnected ATF fitting(purchased from the local hardware store--3/8, 5/16, or 11/32" hose). Aim both hoses into the bucket. When you start the vehicle, your ATF will flow out of 1 of the hoses. Do the flush and label the ATF flow with a paint pen for future flushes(not needed if you practice the simple yearly drain/refill once or twice a year).
Also, if there is ATF flow in P or N, there is no need to have your helper put the tranny in D.
#525543 - 07/02/06 07:34 AM Re: ATF cooler return line - which is it???
FazerZ Offline
Loc: Charlotte, NC
Actually on Honda transaxles, the cooler return line is easy to spot. The cooler return line always goes to the differential part of the case. This is right above the area where the axles go into the transaxle (near the speedometer or vss if present).
Typically this is the line on the tranaxle closest to the firewall.
In the illustration, it's the blue line. Good guess Tyrant. [Big Grin]
DH
#525544 - 07/02/06 09:16 AM Re: ATF cooler return line - which is it???
Ken2 Offline
Loc: Washington St.
All you need to do is to disconnect one line, disable the engine so it won't start, and crank it. You'll see ATF flow.
Ken
