Strjock81, I know what you mean about fluids in different applications. I have to say that I think the difference between the pickup and the tractors is that the tractors were designed at the outset with pulling in mind. They also need MORE weight rather than less to get traction in the field. These days pickups are essentially designed as automobiles that might happen to tow sometimes. So many times their axles/running gear are ludicrously overstressed compared with those in a tractor. So, we have to apply "band-aids" to try to compensate (oil coolers or finned covers for the rear ends, 2,000-hour life spans instead of 20,000 hours, etc.).
