Alan,quote:
Originally posted by Alan:
This is basically the OEM fill for your Audi and it sure ain't a 75W90 despite what the book says.
OEM fill UOA
You could probably get really good results with either a Syncromesh or MTL.
The transmission in the Audi TT uses "G50" manual transmission lubricant, which is a 75W90 transmission lube. The VW Golf discussed in your link uses the "G52" fluid, which is of an ATF-like viscosity.
Redline MT-90 or Amsoil MTG would be the correct lube to use in this transmission. Amsoil recommends their MTG product for this transmission , as shown in their Product Application Guide when you look up the 2001 Audi TT:
quote:
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Synthetic 5W-40 European Engine Oil
-15 To 15°F......10W-30, 10W-40
Above 5°F......15W-40, 15W-50, 20W-40, 20W-50
All Temps......5W-50, 10W-50, 10W-60
All Temps......5W-30, 5W-40, 10W-30, 10W-40[1]
Below 59°F......5W-30, 5W-40
Manual Transmission,.....GL-4
75W-90[2]
Synthetic Manual Transmission and Transaxle Gear Lube 75W-90
Differential, Front .....GL-4[3]
75W-90
Fluids
Power Steering Fluid.....PS
Brake Fluid.....HB
Clutch Fluid.....HB
1. Shown viscosity/temperature combinations are only valid if
an energy-conserving oil is used.
2. GL-4 is synthetic gear oil, VW part no. G 005 000 (G50)
3. GL-4 is synthetic gear oil, VW part no. G 005 000 (G50)
[ March 22, 2006, 11:39 PM: Message edited by: Michael Wan ]
