I'm changing the rear-end fluid in my 99 Crown Victoria with 3.27 non-lock gear. The 2002 Crown Victoria and newer uses 75W-140 synthetic lube. The original spec for mine is non-synthetic 80W-90. My inclination is to use the 75W-140 when I install the Amsoil Severe Gear lube. Anyone have any experience with synthetic lube in the Ford 8.8 in the 1998-2002 Crown Victoria?
