MolaKule
Staff member
That has been my experience amd the message I was conveying above:quote:
maybe when its put back together it will be setup more precisely and the noise will be gone But I think you may be chasing just a noise causd by improper setup of the ring and pinion and likely normal wear and tear.
The shims are little circular metal plates of thin, hardened steel (actually special washers)that set the clearances between the input (drive) pinion and the ring gear. Shims behind the input or drive pinion set the longitudinal distance (forward/rearward relation) to the ring gear tooth, while the ring gear shims set the depth of tooth engagement.quote:
There are generally two kinds of noises in the diffy, one when you coast and one when you accelerate.
It may be the shims in the shim pack has worn in the drive pinion and you are getting a bit more thrust on one side of the ring gear tooth than on the other side, such that the drive pinion/ring gear mesh is not quite up to par.
I would still take the U-joints out and make sure they aren't worn due to inadequate factory greasing.
http://auto.howstuffworks.com/differential3.htm
Like Mike said, if you are really concerned, have it torn down and inspected, otherwise use a GL5 HD 18 cSt Gear Lube and ignore the noise.
[ February 13, 2005, 02:56 PM: Message edited by: MolaKule ]
