I'm in the process of resurrecting my fiance's 1968 MGB.
This car has a 4-spd manual with electronic overdrive. It has synchromeshed gears on 2-3-4 and the overdrive has a wet clutch arrangement. The manual calls for 20W-50 motor oil.
I HATE the idea of running motor oil in this tranny. Yes, hundreds of thousands of MGB trannies have run just fine on this, but I think we all can agree that there is NO WAY 20W-50 oils have the shear stability to handle 10-20k mi drain intervals in this application.
The tranny fluid is a pita to change and I really don't want to do it at every oil change.
On the various MGB boards, lots of posters have claimed success with MT-90, but ONLY on non-overdrive trannies. With the overdrive units, it causes slipping. The same has been reported with synthetic 50 wt motor oils.
Also, these units are full of yellow metals, so anything GL-5 is out of the question.
Thus, it looks as though I need a shear-stable GL-4 90 wt. dino with as little friction modifier as possible.
Any ideas?
Any ideas?
